RC3: Uninstall problem on Windows XP
It seems there is some problem with the uninstaller in Salamander 2.5 RC3 caused by Windows Vista XML manifest we included in remove.exe.
We have reports from some Windows XP users that uninstaller doesn't work -- it does nothing.
We are sorry for inconvenience, we are working on this problem right now.
Workaround: download old version of the uninstaller:
http://www.altap.cz/upload/remove.rar (6KB)
unpack it over existing Program Files\Altap Salamander 2.5 RC3\remove.exe and run it.
McLion
Post by McLion »
I tried this. Still there is one file that can not be deleted: \plugins\salamext_1.dll
Franz
This file will be silently removed after Windows restart (is locked by Windows Explorer).
McLion
Post by McLion »
Worked :D ! Silly me, not to try this first :oops: .
Thanks for the swift answer and best regards,
Franz
dprice
Post by dprice »
The above download link is not working. Can you take a look when you get a chance?
Thanks,
Derek
Our web site is down due to DoS attack, I'm sorry.
The file is attached below.
remove.rar
Working version of Salamander 2.5 RC3 uninstaller.
(5.91 KiB) Downloaded 430 times
dprice
Post by dprice »
That was fast! Do you guys ever sleep? :D
Thanks!
Derek
It is 6pm in Czech Republic ;-)
