File permissions dialog
very valuable feature
I happen to use that permissions feature on a day to day basis with drives that have corrupted ntfs permissions.
It works wonders!
please re-introduce it as i never had a problem with it not working properly! thanks guys!
It works wonders!
bug with "permissions" functionality
Dear Jan, I am very sorry to say that I use the English version and I still have this bug. Because of it I had to switch back to the 2.0 versionJan Rysavy wrote: Regarding your question: we will try to fix the problem with localized Windows (wrong tab is opened). English Windows looks to work well.
Re: bug with "permissions" functionality
Is the Security tab displayed in Properties dialog box?lukasc wrote:Dear Jan, I am very sorry to say that I use the English version and I still have this bug. Because of it I had to switch back to the 2.0 version
Did you disable the simple file sharing in Windows?
As someone already said , turning off simle file sharing is no way to workaround the bug.Jan Rysavy wrote:Is the Security tab displayed in Properties dialog box?lukasc wrote:Dear Jan, I am very sorry to say that I use the English version and I still have this bug. Because of it I had to switch back to the 2.0 version
Why ? Windows Networking is a mess, moving files out and into a shared directory doesnt mean the files gets the permissions set right and you need
always to re hash permissions. Its annoying.
More than one ppl wants the feature back the way it was on old Salamander, so say plz clear if you are working on it or not.
We will not return to the old dialog box. It is possible to implement it as plugin and we have it on our to-do list. Such plugin will not be included in standard Salamander distribution (will be available on download page).katsuhiko wrote:clear if you are working on it or not.
The better solution will be re-implement this dialog box in Salamander, but it looks like a lot of work.
While testing the German translation of Salamander 2.52 I noticed that this issue is still there, running now under German version of Windows 7 Ultimate RTM.
But, if the command simply opens the Windows properties dialog, the question is if it is of any use at all.
Re: File permissions dialog
Problem will be fixed from AS 2.53.th. wrote:Ctrl+P or Files->Security->Permissions in the menu brings up the file properties dialog instead of the file permissions dialog.
