OpenSSL - libraries problem
ivo
Post by ivo »
Hello,
after upgrading Salamander from version 2.54 to 3.06 I have found out that sometimes, when using FTP client plugin I am getting the following error:
After further inspection I can say, that the error dialog opens only after pushing Connect button from Connect to FTP server plugin window, when "Encrypt control connection with TLS/SSL" is checked.
Ivo
Re: OpenSSL - libraries problem
Hi Ivo,
What Windows version are you using? Altap Salamander 3.06 already contains OpenSSL libraries (C:\Program Files (x86)\Altap Salamander\utils\libeay32.dll and ssleay32.dll). It looks like some problem with paths.
ivo
Post by ivo »
Hello Jan,
Thaks for your reply. You are right, the libraries are in this folder. So, do you think is it possible that problem arises because I only unzipped version 2.54 (I guess there were no OpenSSL libraries) and then I upgraded to version 3.06 and no path were set in my environmet during previous installation process?
I usually prefere such clean and portable installations :-)
Ivo
ivo
Post by ivo »
Ajaj,
I am sorry I forgot.
Windows XP Professional, version 2002, SP3
Thank you, we will fix this problem in Altap Salamander 3.07, we are finishing it right now, it should be released next week. Please let us know if it solved problem for you. Have a nice weekend!
ivo
Post by ivo »
Thank you for info
Ivo
ivo
Post by ivo »
Hi Jan,
I would like to ask about any news regarding the release 3.07?
Ivo
We are nearly there, I'm sorry for the delay. It looks we will release 3.07 during next week.
ivo
Post by ivo »
OK, no problem.
Good luck!
ivo
Post by ivo »
Jan Rysavy wrote:We are nearly there, I'm sorry for the delay. It looks we will release 3.07 during next week.
Any progress?
Ivo
We are fixing one problem we discovered recently. AS including version 3.06 doesn't support application shutdown protocol described in Application Shutdown Changes in Windows Vista. It causes problems with AS corrupted configuration like http://forum.altap.cz/viewtopic.php?f=2&t=3972 or http://forum.altap.cz/viewtopic.php?f=2&t=3326. We want to have it fixed for AS 3.07. I'm sorry for delay.
ivo
Post by ivo »
Thank you for your reply.
Good luck.
Ivo
Ivo, can you confirm if the problem is fixed in v3.07?
ivo
Post by ivo »
Hello,
the problem seems to be solved in 3.07.
Thanks
Ivo
