TortoiseSVN 1.8.11, Windows 7 x64
Displayed fine in Explorer
AS x86 (works in x64)
Nothing helps, reboot, reinstall, killing of TSVNCache.exe process
													TortoiseSVN overlays not displayed (x86) [Solved]
- crystalidea
						- crystalidea
Re: TortoiseSVN overlays not displayed (x86)
Had to reinstall Windows eventually
						Re: TortoiseSVN overlays not displayed (x86) [Solved]
Maybe they were disabled in Salamander's configuration? Or the limit kicked in?
