Salamander says that the file is either a part of the multi-volume archive or is corrupted. However, Winrar 3.70 handles the file with ease. I'll send a link to the file to a Salamander support person or developer via PM.
By the way, http://www.altap.cz/salam_en/plugins/zip.html lists old stuff.
I found a zip file that Salamander 2.52 doesn't handle
Re: I found a zip file that Salamander 2.52 doesn't handle
You can send it to support (at) altap.cz or directly to me to support (at) pictview.com, i.e. using the standard support channels.roman2 wrote:Salamander says that the file is either a part of the multi-volume archive or is corrupted. However, Winrar 3.70 handles the file with ease. I'll send a link to the file to a Salamander support person or developer via PM.
I've got the 195MB file in question. It is actually a .RAR archive. Rename the file to *.rar, Salamander will then handle it as expected.roman2 wrote:Salamander says that the file is either a part of the multi-volume archive or is corrupted. However, Winrar 3.70 handles the file with ease.
I see. Could then the plug-in be improved to detect these kinds of situations? Winrar could do it. IrfanView does a similar thing with images (there have been many situations when images had wrong extensions, and IrfanView informed me about it and offered to rename the files instead of simply failing). PictView plug-in simply displays images in these cases (not ideal behavior).
We plan to support Ctrl+PgDn for opening archive with non-associated unpacker. It would be possible to open .EXE self-extractcting archive this way or for example recently supported .CHM archive.
Downloads can get corrupted for a variety of reasons. In IE8, the CONTENT.IE5 directories may be full or nearing capacity.
Batch script that I use to assure clean out of IE5 dirs -
Download attached zip, extrect batch script, RIGHT-click on icon, "Run as Administrator"
Also, I download 1,000's of system files + BSOD kernel memory dumps each day and for whatever reason, sometimes the 1st download is corrupted and I get the error message about multiple volumes -- when there are none. I simply try the download a 2nd time before troubleshooting the situation. I deal mostly with zip, RAR and cab files and do get the ocassional files with mis/re-named file ext as is mentioned here.
Regards. . .
jcgriff2
Regards. . .
jcgriff2
- IE5_DEL_v2__jcgriff2_.bat.zip
- (502 Bytes) Downloaded 1052 times
J. C. Griffith
Microsoft MVP
Windows Expert - IT Pro
Microsoft MVP
(What are the "capacity limits" for CONTENT.IE5 or how would one know it is getting "full"?
Never mind, found it.
IE, Internet Options | General, Browsing History -> Settings.
Never realized that existed. <I've seen some HUGE TIF directories in my time>.)
