WinSCP plugin - where are you? ;)
It looks OK, try to calculate MD5 checksum using Plugins > Checksum menu.
It should be 980FEFDB206BA5AA5744125D09CA66B1
Size 773 963 bytes.
jis
Re: as25fix3.zip corrupt?
Post by jis »
wsadkin wrote:http://www.altap.cz/fix25/as25fix3.zip
seems to be corrupt; neither Salamander nor Winzip can open it. Is there something that can be done to at least fix this?
Try to empty your cache and download it again, because this archive is ok. I think, that there must be problem on your side.
Please, compare your download with these parameters:
File Size = 773963
Time Stamp = 26.09.07 06:54:06
CRC = FF468849
MD5 = 980FEFDB206BA5AA5744125D09CA66B1
EDIT: I am sorry, I overlooked your post Jan.
jis wrote:EDIT: I am sorry, I overlooked your post Jan.
Better than silence ;-) Thanks!
Purchase pages for version 2.5 are nearly finished, we will finish them in half of November.
You can download new version of Altap Salamander 2.5. Reminder for unregistered plugins (WinSCP and PictView) is inactive until December 1, 2007.
Download it from: http://www.altap.cz/fix25/as25fix4.zip
Installation: replace original salamand.exe file in your Altap Salamander 2.5 installation with supplied new version of salamand.exe (overwrite it).
Guest
Post by Guest »
Petr Solin wrote:Installation: replace original salamand.exe file in your Altap Salamander 2.5 installation with supplied new version of salamand.exe (overwrite it).
Just out of curiosity, why does salamand.exe need to be replaced? I'd assume winscp.spl would need to be replaced as this one is checking the plugin license.
dsznajder
Post by dsznajder »
Petr Solin wrote:Purchase pages for version 2.5 are nearly finished, we will finish them in half of November.
Hm, maybe this is sign that this should be free? ;)
Anyway - December is comming and I think maybe 2 month delay for now will be OK? :)
Dariusz Sznajder
Jouda
Send me please as25fix3.zip
Post by Jouda »
Hello I lost my backup. I missing this file: as25fix3.zip
Please send me as25fix3.zip to: tz(dot)jouda[at]centrum/dot\cz
Thnak You very much.
P.S. I have Fix1, Fix2 and Fix4. Missing Fix3 :'(.
Re: Send me please as25fix3.zip
Jouda wrote:P.S. I have Fix1, Fix2 and Fix4. Missing Fix3 :'(.
What do you want to do with it? Start a collection?
These fixes do not depend on each other. Fix3 prolonged ability to use unregistered plugin till Nov. 1st. This date is history.
Fix4 prolonged it till Dec. 1st. I did not test anything, but according to the facts posted, the only possibility of using the plugin at his time is evaluation mode.
dsznajder
Post by dsznajder »
In fact Dec 1st is history too and we still can not spend our money and must see nag screen :\
Dariusz Sznajder
We are very sorry for all that delays. We have finally released these purchase pages: http://purchase.altap.cz/purchase/
dsznajder
Thanks
Post by dsznajder »
Thank you.
Bought and waiting for keys (and 2.51 too :wink: ).
Dariusz Sznajder
We are doing our best to release Altap Salamander 2.51 during next week.
dsznajder
Post by dsznajder »
:D
Dariusz Sznajder
It's like it's gonna be a Christmas present from you. 8)
