Export
Posted: 26 Dec 2014, 23:33
by mavin
how to copy only directory names to excel
Re: Export
Posted: 31 Dec 2014, 19:59
by Ether
Could you provide more details? You can start with menu Commands > Make File List....
Re: Export
Posted: 02 Jan 2015, 02:56
by mavin
I don't have the "make file list" command in the free version. I am trying to find out if this will allow me to high-lite the folder names i want and then create a list of these folder names and export the list to excel. If I can confirm that this will work in the regular version I will purchase it.
Re: Export
Posted: 02 Jan 2015, 12:23
by thomas
First select the folders to export.
Open the command "make file list":
Use STRG+M or menu/commands/make file list.
Then you can use for example "$(FileName)$(CRLF)"
Re: Export
Posted: 02 Jan 2015, 19:29
by Ether
Download trial version of Salamander v3.0 and follow the steps as written by thomas. Leave Clipboard selected in the Make File List window and press OK. After that, you can paste (Ctrl+V) your list into Excel.
