Shell Link Viewer Plugin
Posted: 24 Aug 2009, 23:39
by stepand76
Shell Link Viewer is plugin for view information on Windows shortcuts.
Plugin is available here:
http://sites.google.com/site/stepand76/asplugins-enu
You can discuss the plugin in this thread.
Any comments, suggestions and feature requests are welcome.
Re: Shell Link Viewer Plugin
Posted: 22 Oct 2009, 22:20
by stepand76
Version 0.5.0 (23.10.2009)
[+] Added the "Focus" command (F) - focuses the file in the panel.
[+] New keyboard shortcuts (Ctrl+F, Ctrl+T) assigned to the "Go to Target" command.
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancement
Posted: 09 Feb 2010, 12:56
by th.
I've been downloading the shelllinkviewer_0.5.0.399.zip from your site, but when installed it says Version 0.4.0?
Furthermore, there are 2 items labeled "Start in" whereas the second of them should be "Comment" I guess.
Posted: 09 Feb 2010, 16:14
by stepand76
Thank you. I will look at it.
Posted: 21 Feb 2010, 10:04
by stepand76
Fixed (will be available next week).
Posted: 25 Feb 2010, 12:11
by stepand76
Version 0.6.0 (25.2.2010)
[*] Built with Delphi 2010.
[+] Enhanced "About" window.
[+] Added an option to save possion and size of viewer's windows.
[+] Added an option to prefer keyboard shortcuts in main menu.
[+] Added a command to execute the target file.
[-] Fixed version number in the About window.
[-] Fixed labels in viewer.
Legend
[*] Change
[-] Bugfix
