FLAC Viewer Plugin
Posted: 10 Jan 2009, 20:12
by stepand76
FLAC Viewer is plugin for view meta information on FLAC (Free Lossless Audio Codec) files.
Plugin is available here:
http://sites.google.com/site/stepand76/asplugins-enu
You can discuss the plugin in this thread.
Any comments, suggestions and feature requests are welcome.
Posted: 28 Jan 2009, 12:46
by stepand76
Version 0.2.0 (28.1.2009)
[+] Texts moved to SLG file (now it is possible to translate plugin to other languages).
[+] Added version information (VERSION_INFO) into plugin binnary files.
[+] Added plugin icon and icon of viewer window.
[-] Fixed placement of viewer window.
[-] Fixed showing of message dialogs (icon, set of buttons).
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancement
Posted: 04 Feb 2009, 10:08
by stepand76
Verze 0.3.0 (4.2.2009)
[+] Added compatibility with AS 2.52 beta 1.
Legend
[*] Change
[-] Bugfix
Posted: 25 Feb 2009, 22:54
by kumar
Thanks a lot for this plugin! It would be great to see picture (metadata) in viewer? Is it on roadmap?
Posted: 26 Feb 2009, 08:57
by stepand76
Yes, it is planned, but I'm busy last days, so I cannot estimate when it will be done.
Re: FLAC Viewer Plugin
Posted: 22 Aug 2009, 01:25
by Eric
Thanks for the plugins.
It seems, that they don't work anymore with 2.52 beta 2 (JSON and Flash neither)
even though it's noted in the release notes:
Altap Salamander 2.52 is now backward compatible with plugins for versions 2.5 and 2.51.
Thanks for any update.
Posted: 24 Aug 2009, 23:30
by stepand76
Version 0.4.0 (24.8.2009)
[*] Fixed compatibility with AS 2.5, 2.51 and 2.52 beta 2.
[-] Fixed Alt+Space navigation in viewer.
[*] New view style (requested by ether).
Legend
[*] Change
[-] Bugfix
Posted: 25 Aug 2009, 13:42
by Eric
Great, thank you.
Eric
Posted: 22 Oct 2009, 22:18
by stepand76
Version 0.5.0 (23.10.2009)
[+] Added the "Focus" command (F) - focuses the file in the panel.
Legend
[*] Change
[-] Bugfix
Posted: 04 Mar 2010, 13:42
by stepand76
Version 0.6.0 (4.3.2010)
[*] Built with Delphi 2010.
[+] Enhanced "About" window.
[+] Added an option to save possion and size of viewer's windows.
[+] Added an option to prefer keyboard shortcuts in main menu.
Legend
[*] Change
[-] Bugfix
Posted: 10 Mar 2010, 15:51
by svyr
I'm getting a very strange bug with the latest version of the plugin (on any file i try to view tags for):
it looks like the delimiters aren't read correctly or something, so the tags aren't properly divided into sections for display.
I've attached a screenshot of the proper tag in aimp and what I get in 0.6.0
Posted: 11 Mar 2010, 10:36
by stepand76
svyr wrote:I'm getting a very strange bug with the latest version of the plugin (on any file i try to view tags for):
Thanks for the report. I will look on it.
Posted: 11 Mar 2010, 14:49
by stepand76
Version 0.6.1 (11.3.2010)
[-] Fixed reading of metadata.
Legend
[*] Change
[-] Bugfix
Posted: 11 Mar 2010, 16:59
by svyr
Thank you for the quick fix ! Tested and looks to be working.
Posted: 08 Feb 2013, 02:55
by natri23
plz update this to the latest beta
