Page 1 of 2
Flash Player Plugin
Posted: 30 Dec 2008, 18:14
by stepand76
Flash Player is plugin for playback of SWF (ShockwaveFlash) files.
Plugin is available here:
http://sites.google.com/site/stepand76/asplugins-enu
You can discuss the plugin in this thread.
Any comments, suggestions and feature requests are welcome.
Posted: 28 Jan 2009, 12:44
by stepand76
Version 0.3.0 (28.1.2009)
[+] Texts moved to SLG file (now it is possible to translate plugin to other languages).
[+] Added version information (VERSION_INFO) into plugin binnary files.
[+] Added plugin icon and icon of viewer window.
[-] Fixed placement of viewer window.
[-] Fixed showing of message dialogs (icon, set of buttons).
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancement
Posted: 04 Feb 2009, 10:06
by stepand76
Version 0.4.0 (4.2.2009)
[+] Added compatibility with AS 2.52 beta 1.
Legend
[*] Change
[-] Bugfix
Re: Flash Player Plugin
Posted: 28 Apr 2009, 14:55
2 veci
- pokial vyzoomujem daky objekt cez celu obrazovku a "pretecie", nemam moznost presunu na inu vyzoomovanu cast. Tu by sa zisla moznost drag&drop podobne ako v Adobe Photoshop, ked pri drzani medzernika mozno pomocou mysi hybat celym obrazkom.
- moznost zapamatat si posledne nastavenie ZOOMu pri prechadzani adresara. (je strasne otravne neustale zoomovat, ked clovek prezera mrnave objekty)
ENGLISH
2 Things
- When the object is zoomed over the edges, there is no possibility to see behind the edge. It would be nice to have a drag&drop feature like in Adobe Photoshop where you can drag the image around while holding stahe space key.
- it would be also nice to have the ZOOM setting remeber its last value while browsing through a list. Its a bit boring to zoom on every small object you are viewing.
Posted: 25 May 2009, 15:41
by kumar
What about generating exe from swf (create projector file)? I would appreciate it.
Posted: 25 May 2009, 22:42
by stepand76
kumar wrote:What about generating exe from swf (create projector file)? I would appreciate it.
It will be available in next version. My plan is to release it after AS 2.52 Beta 2.
Posted: 25 May 2009, 22:55
by stepand76
Thank you for info and suggestion.
I understand. But I'm not sure if it (remember zoom) is a common feature in other viewers. I will think about it.
Posted: 27 May 2009, 02:16
stepand76 wrote:I understand. But I'm not sure if it (remember zoom) is a common feature in other viewers. I will think about it.
Option might not be common, but is often requested.
Posted: 15 Jul 2009, 03:11
johndavid wrote:have Ubuntu 8.04 - the Hardy Heron - released in April 2008 on my machine, which is fine. However when I try to install flashplayer I get this error. Your architecture, \'x86_64\', is not supported by the Adobe Flash Player installer. The flashplayer i downloaded was this one install_flash_player_10_linux.tar.gz. I chose this because I couldn't see any more appropriate should I be trying a different one, and can anyone tell me which its. Thanks
Buddy, I don't want to be rude, but i believe you are in the wrong forum.
You should check
http://ubuntuforums.org/ or simmilar pages.
Posted: 15 Jul 2009, 16:55
by Tomas Kopal
There seems to be someone posting what looks like legitimate posts just to add a footer with a hyperlink(s). I treat it as spam and delete it when I find it. You can report such posts so we can delete it sooner...
Posted: 24 Aug 2009, 23:31
by stepand76
Version 0.5.0 (24.8.2009)
[*] Fixed compatibility with AS 2.5, 2.51 and 2.52 beta 2.
[-] Fixed Alt+Space navigation in viewer.
[+] Added command to create projector (requires enter path to standalone Flash Player).
Legend
[*] Change
[-] Bugfix
Posted: 22 Oct 2009, 22:19
by stepand76
Version 0.6.0 (23.10.2009)
[+] Added the "Focus" command (F) - focuses the file in the panel.
[-] Fixed a bug when loading configuration for the first time (during plugin installation).
Legend
[*] Change
[-] Bugfix
Posted: 23 Oct 2009, 05:31
by vld
I have several SWF games in the same folder I accidentally found out tonight that if you hit the spacebar while in that particular SWF, it moves you to the next SWF file.
Posted: 23 Oct 2009, 10:56
by stepand76
vld wrote:I have several SWF games in the same folder I accidentally found out tonight that if you hit the spacebar while in that particular SWF, it moves you to the next SWF file.
Is it related to latest version only? I guess it is old "feature".
Anyway I don't know how to solve it. I like the Space key to switch to the next file because it is usual in other viewer plugins for that action. I can do an option for ignoring shortcuts, but I'm not sure if it is the right way...
Any suggestions?
Posted: 23 Oct 2009, 11:16
A checkbox "[x] send keystrokes directly to flash application" (i.e. ignore all keystrokes except Alt+F4 for close application.) or a toolbar button (on/off) in the viewer window would help.
May someone can provide a better name for this option.
