I often find myself working on the server using multiple tools/connections. And there is a problem if I create a new file in the directory using different tool than WinSCP, because WinSCP doesn't see it. In such case I need to either disconnect and connect again or upload and delete a file, just so WinSCP refreshed the content of remote directory.
Is there any chance of adding a "Refresh" option to WinSCP plugin, so to force it to show actual content of remote directory?
Thanks,
Grzegorz
WinSCP "Refresh" option.
Re: WinSCP "Refresh" option.
The Refresh command (Ctrl+R) doesn't work in this case?
It does! I haven't noticed it before - I somehow expected it to be in the context menu of WinSCP "drive".
Now I see it present in the menu "Left" and "Right", also Ctrl+F9 or Ctrl+R. I wish I knew it earlier.
Thanks for the help!
