Please add a feature to enable a folder tree in each panel.
Ideally I would like to have a display/hide folder tree button in each panel toolbar.
The folder tree should have options to define background color and display font independently of the file panel.
It would be nice if the folder tree of the right file panel could be made to appear on the right of that panel instead of the left.
Thanks!
REQST: Dual folder trees No. 1
Mouse-centric, Registered
A competitor commander has introduced folder trees in a new beta version. They are very incompletely and narrowly implemented to the extent that they are essentially useless beyond simple navigation. Feedback from the developer suggests that no improvements are planned, either.
Please, Salamander developers. Do not consider implementing folder trees unless you support the following:
- Individual tree visibility toggles for each side of Salamander.
- Full drag and drop functionality between trees
- System context menu available for folders in each tree
- Full functionality for folders in each tree: in-place renaming, delete, etc.
- Ability to hide folders in associated file panel of each tree
Also, if you plan to implement a tabbed interface to Salamander, associate a subordinate folder tree with each tab and store its visibility with the tab.
Oh, and hurry up, too!
TreeView would by useful
I would also appreciate a treeview, because it's the quickest way how to "index" or quick look for folders content. the NC style was like this. also windows explorer.
In one pane tree, and in other automatically listed content when moving trough tree.
