How can i easy check the MD5 hash of a single file?
Right now i have to create a new text file and paste the hash and the file name in it `?
I suggest this way:
- download a file
- select this file
- choose "Check sum verify"
- copy and paste the hash from the web side in an dialog
- the dialog should show "Verified" and "Store hash as *.md5..." or "miss match"
Or maybe in the "Calculate-Dialog" ?
- selcet a file
- choose "Calculate check sum"
- right click a file and paste the hash from the web side
- see "match" or "miss match"
MD5 check sum handling improvement
I use now an Hash-Tool from Dirk Paehl, DPA_SHA 1.96.ZIP ~80kB and Freeware.
That tool will do nearly what i want.
I have the dpasha.exe in my Plugin folder and an entry to it in my user menu.
If i wanna check an download i do the following:
1) Copy the hash from the webside to the clipboard....
and download the file
2) Drag and drop the downloaded file (here "DPA_SHA 1.96.ZIP") to the hash tool in the user menu bar
3) Press "<- Clipboard" to insert the hash from the clipboard,
maybe select an other hash type... (must be the same type as the hash at the webside)
and press "Compare"
That's all and simple.
Edit:
http://www.dpaehl.de/
and press "Compare"
Edit:
AbteriX
