Disconnect network drive
Guest
Condition:
-"My documents"-folder isn't located in the user profile
(Beta 11)
if I disconnect a network drive, I get an error that salamander can't change the directory to "userprofile\my documents".
Can anyone reproduce it.
Is it a failure by myself, or is the "my documents"-folder hard coded and not taken from the system settings ?
(Beta 11)
Guest
Re: Disconnect network drive
No, it's taken from system, but only when Salamander is starting without saved configuration in registry. If Salamander loads configuration from registry, it loads also this variable from registry, so it doesn't get My Documents path again from system and uses "old" value. Maybe we should change this.Guest wrote:Is it a failure by myself, or is the "my documents"-folder hard coded and not taken from the system settings ?
Let me know if your My Documents path may change during work (e.g. after some login to network drive). Or if My Documents path is always the same and the only problem is that we have the old value loaded from configuration.
Guest
I don't change the My Documents while working.
My Documents path is always the same. You should take it while starting from the system values. I have an old setting, which I created with another location of my documents folder. THX
Why switch you back to this folder and not to last local drive and directory from this panel before ?
For now many thanks. A great forum.
OK, I'll patch it.Guest wrote:I don't change the My Documents while working.
This is easier.Guest wrote:Why switch you back to this folder and not to last local drive and directory from this panel before ?
Guest
Thanks a lot.
In my case this configuration works:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Altap\Servant Salamander 2.5 beta 11\Configuration]
"If Path Is Inaccessible Go To"="D:\\"
If I disconnect, Salamander checks that my documents no exist and it redirect to "If Path Is Inaccessible Go To"-Path.
However, so can you specify any path where you want to be redirected after disconnect, wihthout the enforcement to take a system folder.
Maybe a workaround ?
PS: Moreover any folder/drive may easily cease existing - The hard truth
When path in panel is not accessible (e.g. disconnected network drive):Guest wrote:If I disconnect, Salamander checks that my documents no exist and it redirect to "If Path Is Inaccessible Go To"-Path.
-it tryies to go to "If Path Is Inaccessible Go To"-Path
-it previous attempt fails, it goes to "fixed drive" (root of disk with system)
Is it OK? Or do you suggest some change in this behaviour?
Guest
@Petr Solin:
It is OK.
Is it possible to pick up the setting for the
"If Path Is Inaccessible Go To"-Path to the Configuration Menu ?
So is anyone able to change the location.
@omega:
Set the path hard to c:\ I don't prefer , because I use different drives and i would like to set it up to my favorite. Do you agree ?
It is OK.
@omega:
