Details of the directory in the right panel
Re: Details of the directory in the right panel
Hi, the only way to have this behavior is to write a custom "auto sync" plugin. Salamander does not natively support this.
As far as I know, there is no such plugin. You would have to write it your self using the SDK. Or ask someone to do it.
