The package can be downloaded from http://www.pictview.com/salamander or directly http://www.pictview.com/ev111ge.exe
NOTE: This package only contains the plugin core. Necessary file format modules are part of the Full version of Salamander. Therefore this package does not work with the Standard version.
NOTE: If you prefer archives over self-extracting installers, just rename the .EXE file to .CAB.
NOTE: This official localization has nothing in common with the low-quality unofficial translation seen elsewhere in these forums.
Info: Eroiica Viewer displays Office documents (MS Word, MS Excel, Rich Text Format, WordPerfect, MS Write, Adobe PDF, PostScript), Windows metafiles (WMF, EMF) as well as engineering drawings (AutoCAD DWG, DWF & DXF, Microstation DGN, HP-GL, HP-RTL, HP PLT, IGES, RIS, ESRI Shapefile, Computer Graphics Metafile CGM, Gerber, Micrografx DRW etc.) instantly inside Servant Salamander without loading heavy native applications.
Eroiica Viewer is a demo member of the Eroiica Application family that consists of a number of tools, libraries (ActiveX, COM servers, DLL modules) and especially of the scalable Eroiica Imaging application for viewing, printing, redlining, annotating, editing, converting and managing documents from hundreds of sources and in various languages. Eroiica is scriptable via API and DDE and suits well for integration purposes. See more at http://www.parallax69software.com or Eroiica's main features. Pricing starts at US$ 69 for a single-user license.
Thomas, thank you for the good job!
