WinSCP v1.6.1 is available but not in v2.51 of salamander :(
Postby grymmjack » Fri Oct 03, 2008 6:14 pm
http://winscp.net/eng/docs/salamander_h ... on_history
1.6.1 it says.
Yet in my plugin manager it reports 1.5.1
Can we please get the new version of this plugin? I've paid for it long ago and would like an update to fix (hopefully) several bugs..
* Changes in the plugin itself:
o Bug fix: Plugin occasionally hangs when background transfer have outstanding prompt displayed.
* SSH/SFTP/SCP core upgraded to WinSCP 4.1.5. It brings following changes:
o Workarounds for OpenSSH-specific bugs are applied with Sun SSH as well. 228
o Most lists can be scrolled while item is dragged, particularly stored sessions list. 241
o More verbose error messages are shown when operation with local file fails.
o Ignoring less than 2 seconds timestamp difference when synchronizing. 249
o Bug fix: Failure on tunnel connection termination. 187
o Bug fix: No help page was associated with Save session dialog.
o Bug fix: Authentication dialog displayed multiple prompts incorrectly.
o Bug fix: Authentication prompt for tunnel sessions was not marked properly.
o Bug fix: Key passphrase prompt was not being localized.
o Bug fix: Failure when moving files from remote directory with SCP. 206
o Bug fix: Default log file path still used &s pattern instead of !s. 224
o Bug fix: Plugin hanged when dummy protocol command was dispatched to keep session alive, while reconnecting.
o Bug fix: Plugin hanged when server stopped receiving data.
o Bug fix: Plugin was stealing ports binded to by other applications when setting up SSH tunnel. 188
o Bug fix: Plugin hanged when change was detected while session is disconnected. 230
grymmjack
Re: WinSCP v1.6.1 is available but not in v2.51 of salamander :(
Postby zdhacz » Fri Oct 03, 2008 8:39 pm
I speak for releasing the new version of this plugin too.
I suffer with already solved bug "Plugin occasionally hangs when background transfer have outstanding prompt displayed." often enough (several times a day) :(
Thanks,
zdhacz
zdhacz
Postby grymmjack » Fri Oct 03, 2008 9:31 pm
yes. i have the same problem. :(
grymmjack
Postby Jan Rysavy » Mon Oct 06, 2008 1:11 pm
Please contact me on my email jan.rysavy@altap.cz. I will send you updated version of WinSCP plugin for Altap Salamander 2.51.
Postby grymmjack » Mon Oct 06, 2008 2:36 pm
Jan Rysavy wrote:Please contact me on my email jan.rysavy@altap.cz. I will send you updated version of WinSCP plugin for Altap Salamander 2.51.
thanks Jan. Great customer service as usual :)
grymmjack
Postby jis » Mon Oct 06, 2008 8:29 pm
Will be the updated version of WinSCP plugin available through Altap Salamander Update for the rest of users?
Salamander fan since 1998
My current OS's: WXPPSP3, WVHPSP1 and W7UB7000.
jis
Postby Jan Rysavy » Tue Oct 07, 2008 7:48 am
We plan to include it in Altap Salamander 2.52 beta 1. We can release separate update only for WinSCP plugin, but it will take some time, so we prefer this way right now...
Postby jis » Tue Oct 07, 2008 7:41 pm
Ok, I am looking forward for Altap Salamander 2.52 beta 1.
jis
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 0 guests
cron
