Kudos to the winner of the contest. The new icon and splash really give the app some needed spit and polish. I am still getting used to the orange icon instead of the old one though
Keep clicking outlook and firefox
Beautiful icon & splash
As a long time user it is indeed not easy to find the new Icon in the Taskbar (the more so as I have MS-Outlook in Taskbar - looks very similar: http://www.flickr.com/photos/kk0815/97843926/!)
BUT the new Icon / splash screen / About box outweigh this - no doubt!
Kind regards, KNUT
KNUT, same here -- outlook is same color as SS.KNUT wrote:As a long time user it is indeed not easy to find the new Icon in the Taskbar (the more so as I have MS-Outlook in Taskbar - looks very similar!)
It could be a cool feature to provide several different colors of the icon and make it option to select one -- we could go to blue for example like the old icon and quickly glancing it looks a GREAT deal like the outlook icon. I wouldn't be surprised if the designer actually sampled the colors upon closer examination
Anyway small concern. We can hack the icon I think with resource hacker no? Has anyone done this successfully as there are tray hooks for salamander and I know that sometimes reshacks for icons which serve dual roles (taskbar and tray) sometimes screws things up. Plus I'd bet that SS isn't coded in a typical way as the altap guys are gurus
That said what reshacker do you all use to change icons out of apps and has anyone done it with SS b11?
Thanks
That's it - perfect idea - the old blue color with the new wunderful Icon.grymmjack wrote:It could be a cool feature to provide several different colors of the icon and make it option to select one -- we could go to blue for example like the old icon
@Altap: PLEASE... !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Kind regards, KNUT
I like the new icon as well... very visible and clean!
However, that little hi-light (between toes 2 and 3) makes it look (at a glance) like the Salamander has 5 toes: 4 regular toes and one withered. Close inspection shows this isn't the case, but it still bothers me.
This is because most subtle photographic effects do not shrink to icon size very well and tend to "blur" the image (and the iconography)!
Mouse-centric, Registered
