I have a 5 button mouse (including the scrollwheel). If i use windows explorer i can use the 2 other buttons to go back/forward just like in a webbrowser.
Is it possible to implement this functionality in SS?
back/forward functions for folders
Re: back/forward functions for folders
With my Microsoft IntelliMouse (optical, driver version: 5.20.413.0) it works like thisomega wrote:I have a 5 button mouse (including the scrollwheel). If i use windows explorer i can use the 2 other buttons to go back/forward just like in a webbrowser.
Kind regards, KNUT
Back/Forward commands will be supported from SS 2.5 beta 11.omega wrote:I have a 5 button mouse (including the scrollwheel). If i use windows explorer i can use the 2 other buttons to go back/forward just like in a webbrowser.
Interesting...KNUT wrote:With my Microsoft IntelliMouse (optical, driver version: 5.20.413.0) it works like this
- Josip Tosic
Maybe KNUT configured his IntelliPoint to send Alt+Left and Alt+Right?
IIRC, some older versions actually sent these key codes to applications. Gave up on IntelliPoint a long, long time ago. It's friggin' huge, and only has one decent option - scroll acceleration. I can live without it, though.
