Thanks!
Oliver
Yes, under standard conditions Servant Salamander shows correct dialog boxesOliver S wrote:Interesting... but shouldn't an application show its dialogs correctly regardless of the system standard font?
I'm pretty sure I found the changes I made. Simple, really. Under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes, the four values "Helv", "Helvetica", "MS Shell Dlg" and "MS Shell Dlg 2" must be set to "Segoe UI" - or probably to any other font, I don't assume this is a problem with the particular font. But who knowsIf you will find which Registry change causes this problem, we can try to fix it. Let us know.
Oliver, every font has different metrics. The standards are standards for a reasonOliver S wrote:I'm sorry, I didn't have much time recently.
About the font - I have indeed configured a different from default standard font, but not via the control panel applets. This requires a few changes to the registry, to make Segoe UI (the new Windows Vista standard font) the default on Windows XP. So you think that would be the problem here? Interesting... but shouldn't an application show its dialogs correctly regardless of the system standard font?
I don't think it'll be easy to try and change the font back completely... it requires reboot and everything. Maybe I'll try it one day when I have the time...
Segoe UI: http://en.wikipedia.org/wiki/Segoegrymmjack wrote:Oliver, every font has different metrics. The standards are standards for a reasonI like that font though, it's so smooth. It's called Segoe UI? Any idea who developed it, etc? Thanks Oliver.
Great, thanks for the link.Jan Rysavy wrote:Segoe UI: http://en.wikipedia.org/wiki/Segoegrymmjack wrote:Oliver, every font has different metrics. The standards are standards for a reasonI like that font though, it's so smooth. It's called Segoe UI? Any idea who developed it, etc? Thanks Oliver.
Thanks Oliver, I have fixed this bug.Oliver S wrote:I'm pretty sure I found the changes I made. Simple, really. Under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes, the four values "Helv", "Helvetica", "MS Shell Dlg" and "MS Shell Dlg 2" must be set to "Segoe UI" - or probably to any other font, I don't assume this is a problem with the particular font. But who knows
