I am wondering if it is posible to access a blotooth device
from SS ?
Jorge
Bluetooth ?
Re: Bluetooth ?
A headset? - of course notjorgerhv wrote:I am wondering if it is posible to access a blotooth device
from SS ?Jorge
what kind of device do you mean?
As far as I know some mobile devices can connect to activesync by using bluetooth. Please use google and search for your device+activesync.
http://www.altap.cz/salam_en/newver_archive.html >
# New Windows Mobile plugin:
* Access Pocket PC, Pocket PC Phone Edition, Smartphone, and Windows CE devices from Servant Salamander. Explore your mobile device's directories, view files, copy, move, delete, rename files and directories, or change their attributes.
* Microsoft's ActiveSync software must be installed on the desktop computer to connect plugin with your mobile device.
* Developed by Juraj Rojko.
(o.O) -(@.@)- (/o.O\) ,,,`Q´,,, {~.~} (^.^)
Bluetooth ?
Well, I just purchased a bluetooth USB dongle and it worked good
with my PDA Palm T5 ( I hope it will work ok with my daugther's razor
phone ); but the interface is really ugly, so I think it would be nice
browsing the files with SS.
Jorge
Jorge
Re: Bluetooth ?
Motorola RAZR V3 - Why don't you use the mini USB?jorgerhv wrote:...
Jorge
As far as I know this will work in combination with ActiveSync.
Re: Bluetooth ?
Jorge
I don't think V3 uses ActiveSync cause it doesn't sync with Outlook with the integrated sync-software from Motorola.
Concerning bluetooth: As long as you have a connection with the BT-device and the device supports file transfer via a drive letter, browsing via SS will be no problem.
Greetings
Udo
Udo
