lynx-like motion
lynx-like motion
Midnight Command has an option "Lynx-like motion". This allows to use cursor-right and cursor-left to navigate into and out of directories. It would be really nice to be able to do that in AS, too (as long as AS is not available on Linux and OS X).
Re: lynx-like motion
An Autohotkey script that translates Left to Backspace and Right to Enter in the panels could be used as a workaround.
Just for the records, here is my autohotkey script:
Unfortunately, this also works not just in AS, but now also here in the browser showing "Salamander" in the title.
#SingleInstance Force
#installKeybdHook
#Persistent
SetTitleMatchMode, 2
#Hotstring EndChars `t
; here come my hotkeys, like tia or br
#IfWinActive, Salamander
Left::BS
Right::Enter
#IfWinActive
Try using if WinActive("ahk_class SalamanderMainWindowVer25") instead. I based this piece of code on the example on this page: http://www.autohotkey.com/docs/commands/IfWinActive.htm
I've tried with SalamanderMainWindowVer25 and SalamanderMainWindowVer30 and neither works.
Oh. I tried it myself and it seems it has to be written a bit differently.
#IfWinActive ahk_class SalamanderMainWindowVer25
Left::BS
Right::Enter
#IfWinActiveΕλληνικά rulez.
Thanks. Yes, now it works - though I would not have expected SalamanderMainWindowVer25 to work with AS 3.
Unfortunately, this broke the Alt+Left/Right history navigation.
Maybe you could map those too with AutoHotkey to fix it.mklhmnn wrote:Unfortunately, this broke the Alt+Left/Right history navigation.
Maybe, but I rather prefer to have an option in Altap Salamander. I guess, this couldn't be that difficult to implement.
For me as a linux person I would love to see it in the Salamander too. I even don't think it would be too much work... However, till it is implemented this is the only option to go.mklhmnn wrote:Maybe, but I rather prefer to have an option in Altap Salamander. I guess, this couldn't be that difficult to implement.
